Posted: Tue Jul 15, 2008 9:29 am Post subject: GT i Estate povijest |
History
Here you will find some information in general on the history of the Mini Clubman. Obviously, this is just a small highlight. With 41 years of continuous production behind it (Mini production in general that is), I definitely could not include everything. There's lots of books out there dedicated entirely to the history of the Mini, so if you want a detailed insight into Mini history, I suggest that you go out and get one of those books which have the added advantage of explaining things much better than me One I highly suggest is The Complete Mini by Chris Rees from which I have taken much of the information exposed here.
What, you're still here? Ok then let's start.........
Mini Clubman and Clubman Estate (1969 - 1980)
The Clubman and Clubman Estate were launched in October 1969 along with the new MkIII Minis and sharing their improvements/differences from the previous Minis. The saloon was presented as a more upmarket Mini whilst the estate replaced the curretnly running Morris and Austin Mini estates.
Common to both versions of the Clubman was a compeltely revised front end. The front was extended and became squarer, new grille, bumpers, front headlamps/indicator units and rear 'Mini Clubman' badge.
With regards to the interior, the Clubman retained the the old Super De Luxe specification, but it had a completely redesigned dashboard. A new rectangular instrument nacelle, containing the speedometer on the left and combined fuel gauge/water temperature on the right, was introduced and moved in front of the driver. Also, for the first time in a Mini, the clubman introduced face level ventilation which actually worked. Other features where a unique trim, special contoured seats and its own three spoke steering wheel with a 'Clubman' badge on its centre.
The Estate came with the previous model's rear sliding windows. However, it was never available with the 'woody' rear trim. Instead, it came with a vinyl-coated steel fake wood trims extending the length of the vehicle. These were eventually replaced with contrasting coloured stripes. It also had both left and right wing mirrors where the saloon had none till a single door mirror was standardised across the Mini range in 1973.
While the Estate continued with the previous model's dry rubber-suspension, the Clubman saloon retained the hydrolastic suspension abandoned by most other Minis. It finally gave way to dry rubber in 1971.
Automatic transmission was available on both versions, but when the 1098cc engine was standardized on both models in 1975, the automatic version of the Clubman could only be bought with a 998cc engine.
Apart from interior changes and a minor facelift in 1976, the Clubman remained practically the same during its production life. Post-1976 Clubmans could easily be recognised by their cross-patterned grille.
The Clubman ended production in 1980 with the introduction of the Mini Metro, though the Estate was still available for a further two years.
Other History Facts
1970:
* Steering lock introduced.
1971:
* Suspension on saloon changed from Hydrolastic to rubber cones.
* Improved CV driveshaft boot.
1972:
* Improved syncromesh
* Split-type needle-roller bearings on idler gears
* Alternator standard
1973:
* Rod-shift gearchange introduced.
* Plunging CV joints on inboard ends of new driveshafts.
* Improved door check bracket fitted.
* Single door mirror replaced wing mirrors on Estate.
1974:
* Inertia-reel seat belts standard.
* Heated rear window standard on saloon.
* Twin-silencer exhaust fitted on both models.
1975:
* Cloth seat trim and reclining front seats standard.
* Seat belt anchorages relocated to rear side bins.
* 88oc thermostat standard
* Manual versions of 998cc engined cars discontinued. 998cc-engines versions continued with automatic transmission only and manual-gearbox engine became 1098cc.
1976:
* New black grile with two horizontal bars and cross-shaped motif with new Mini badge in centre.
* Twin coloumn-mounted control stalks fitted.
* New rocker-switch type panel incorporating hazard lights standard.
* Larger pedals from Allegro
* Moulded carpets.
* Ignition/steering lock from BL Princess fitted.
* Suspension modified with softer rear springs and damper settings(saloon only).
* New rubber subframe mounts.
1977:
* New wheel trims.
* Leather-bound steering wheel
* Lockable fuel cap.
* Reversing lights.
* Tinted glass.
* Estate with painted striped down flanks instead of mock wood
1980:
* Mini Clubman models discontinued.
Total production figures:
* Saloon : Approx 275,583
* Estate : 197,606
Total: Approx 473,189
Mini Clubman 1275 GT (1969 - 1980)
The poor 1275 GT was launched along with the Clubman to replace the unreplaceable; the Mini Cooper and Mini Cooper S. Mini Cooper production ended along with the MK 2 Minis as a measure by British Leyland (BL) to cut production costs. Therefore the Clubman was not seen in a good perspective by the many Mini enthusiasts around the world. It received the standard 1275cc engine from BL's production line producing a mere 59 BHP, but with a close ratio gearbox. Performance went down in respect to the Cooper, but in its favour, it was also cheaper. The 1275 GT differed from the standard Clubman in that it had an extra instrument dial; a rev counter. Fron disc brakes from the Mini Cooper S were also fitted as standard. It also had a red GT badge on the front grille, new Clubman 1275 GT rear badge, a stripe just above the sill line with Mini 1275 GT decals, front disc brakes and Rostyle steel wheels.
In 1974, the Clubman was the first Mini to be equipped with 12" wheels from the factory along with larger (8.4") unservoed disk brakes. In general, the Mini 1275 GT shared the same changes as the standard Clubman with a few differences.
1970:
* Final-drive ratio changed from 3.65 to 3.44:1.
1974:
* Tempreature-controlled air intake system now fitted(power output now 54 BHP)..
* Larger non-servoed front disc brakes fitted with larger 12in wheels.
* New 7.5 gallon fuel tank.
1976:
* Old GT badge deleted from grille.
* New triped seats.
* Passenger's vanity mirror.
* Door pockets.
* passenger's door mirror.
* Handbrake grip.
1977:
* Denovo wheels and tyres standard.
1979:
* Black door mirrors and rain gutter standard.
1980:
* Mini 1275GT discontinued.
Total production: 110,673 _________________ Might have 16 valves but still a mini! |
