Using Custom Practice for Hitting in MLB The Show 26
PostPosted: Sat Jan 31, 2026 3:34 am    Post subject: Using Custom Practice for Hitting in MLB The Show 26 Reply with quote
What is Custom Practice Mode?
Custom Practice is a mode in MLB The Show 26 that allows you to practice hitting under controlled conditions. It lets you adjust the settings, such as pitch type, pitch speed, and difficulty, to focus specifically on improving your hitting mechanics. Instead of jumping into a full game or going through random pitches in a standard batting practice, Custom Practice gives you the flexibility to target specific areas of your game that need improvement.
How Do I Access Custom Practice?
To get started with Custom Practice in MLB The Show 26, you need to head to the Practice section in the main menu. From there, select Custom Practice. You’ll be given various options to customize the scenario, including choosing the type of pitcher, pitch speed, and other settings.
This mode is excellent because it gives you full control over the environment. If you're having trouble with breaking balls or fastballs, you can isolate those pitches and practice them until you get a feel for them. Custom Practice isn’t just about hitting, though; it’s a great way to learn how to handle different pitchers and become more comfortable with various pitch types.
What Can I Customize in Custom Practice?
When you enter Custom Practice, you’ll see several settings you can tweak to create the ideal practice session. Here are the main options:
Pitcher Selection: You can choose to face a pitcher from your team, the opposing team, or even customize the pitcher with their pitch mix. If you're focusing on improving against a particular pitcher (like someone with a nasty slider or changeup), this is an excellent option.
Pitch Type: Want to practice hitting fastballs? Or maybe you're struggling with breaking balls and off-speed pitches? You can set the practice session to throw only certain pitch types like sliders, curveballs, or fastballs. This helps target specific areas of weakness.
Pitch Speed: If you're struggling to adjust to faster pitches or need to work on your reaction time, you can adjust the pitch speed. Slower pitches might be useful for refining your timing, while faster speeds will help simulate more game-like conditions.
Difficulty Level: Custom Practice allows you to adjust the difficulty level, too. If you’re a beginner, you can start with lower difficulty settings and gradually work your way up to higher difficulties as you improve your skills.
Fielding Options: You can also choose where you want the balls to be hit to, which can help you practice hitting to specific fields or perfecting your power swings.
With these settings, you can create a tailored practice session that zeroes in on your individual needs, helping you refine your technique and improve your reaction times.
How Do I Improve My Hitting with Custom Practice?
Now that you understand the basic settings, let’s dive into how to use Custom Practice effectively for hitting.
Focus on Timing
One of the most important aspects of hitting in MLB The Show 26 is timing. No matter how good your swing is, if your timing is off, you won’t make solid contact with the ball. In Custom Practice, you can adjust the pitch speed to slow things down or speed them up. Start with a slower pitch speed to build up your muscle memory and timing. Once you get comfortable, increase the pitch speed and work on hitting faster pitches.
Work on Pitch Recognition
Another key aspect of hitting is recognizing what type of pitch is coming. In MLB The Show 26, pitchers throw a variety of pitches, and being able to identify them quickly is crucial for making contact. With Custom Practice, you can set the pitch types you want to face, so you can focus on hitting one specific type of pitch at a time. For instance, if you're struggling with curveballs, set your practice to only throw curveballs and focus on reading the break and timing your swing.
Practice Different Situations
In a real game, you’re rarely facing the same pitch over and over again. To simulate real-game situations, mix up your practice with different pitch types, speeds, and counts. For example, set up situations where you're behind in the count and have to battle back. You can also work on situations like hitting with runners in scoring position or getting the ball into the outfield with less than two outs.
Build Confidence Against Difficult Pitches
Every player has certain pitches they struggle with. Whether it’s a high fastball, a slider on the outer edge, or a nasty changeup, Custom Practice can help you get comfortable facing these pitches. Once you’ve identified the types of pitches you struggle with most, you can set up practice sessions that isolate those pitches and allow you to focus solely on them. Over time, your confidence against these pitches will improve.
How Can I Make the Most of Custom Practice?
While it’s important to focus on specific pitches and situations, there are other tips to help maximize your time in Custom Practice:
Start Slow and Build Up: Don’t jump straight into fastballs at max speed or difficult pitch types right away. Start with easier settings and gradually challenge yourself as you improve. This progression will help you build a strong foundation.
Use the Feedback: MLB The Show 26 provides feedback during practice, letting you know how well you're hitting and where the ball is going. Use this information to adjust your swing or timing as needed. If you're consistently late or early on pitches, adjust your timing or swing mechanics accordingly.
Incorporate Other Game Modes: Custom Practice is a great tool, but it shouldn’t be your only way to practice. Use it in conjunction with other game modes, like Franchise or Road to the Show, to test out your skills in more game-like situations.
Experiment with Swing Types: Whether you're trying to hit for power or focus on contact hitting, Custom Practice lets you experiment with different swing types, including normal, power, and contact swings. Find what works best for you and stick with it.
How Does Custom Practice Help in Real Games?
The beauty of Custom Practice is that it allows you to develop skills that translate directly into in-game performance. Once you've honed your timing, pitch recognition, and confidence in practice, you'll find it much easier to make adjustments in a live game. The more you practice, the more your reactions will become second nature, making it easier to succeed when the pressure is on.
For example, if you’ve been practicing a MLB The Show 26 stubs deal, you’ll find that hitting under pressure becomes a lot easier, since you’ve spent time simulating in-game scenarios. Custom Practice helps you build the muscle memory needed to perform in clutch moments, whether you’re facing a star pitcher in a tight game or just trying to rack up some extra hits in a blowout.
Using Custom Practice for hitting in MLB The Show 26 is one of the best ways to take your game to the next level. By adjusting settings to match your weaknesses and targeting specific pitch types, you can improve your timing, pitch recognition, and overall confidence at the plate. With dedication and the right focus, you’ll see noticeable improvements in your hitting and performance in real-game situations.
