Austin Allegro
Posts: 4 Location: Beograd
Posted: Mon Oct 29, 2007 11:41 am Post subject: Hidroulicna bomba |
| Dakle gde i po kojoj ceni mogu nabaviti zadnju bombu za Austin Allegra? |
Bane_mini Mini Owner
Mini: mini 1275gt, mg metro 1275 Posts: 306 Location: Beograd, blok 45 nbg
Posted: Mon Oct 29, 2007 1:35 pm Post subject: |
| imas kod djure kod starog merkatora... 0112693490 mislim da je oko 100e |
Posted: Mon Oct 29, 2007 11:09 pm Post subject: |
E sad cu se opet malo ja ubaciti i reci da je El Pre pogrijesio...da da ljudi moji he made a mistake
Allegro ne fura na hidrolastik ovjesu nego na HYDRAGAS ovjesu...sto znaci...svaka bomba radi za sebe dok je hidrolastik povezan ljeva dva kotaca i desna dva kotaca...
Evo di sam to procital...ak mi ne vjerujete...
http://www.austin-rover.co.uk/index.htm?ado15storyf.htm
Sorry ElPre...morao sam  _________________ Might have 16 valves but still a mini! |
Luka Mini Owner
Mini: 1979, 1000 SDL Posts: 76 Location: Imotski
Posted: Tue Oct 30, 2007 12:27 am Post subject: Re: Hidroulicna bomba |
Ima kod mene prednje i zadnje ako ti odgovaraju od metra sport 098758580  _________________ Pozdrav |
Posted: Tue Oct 30, 2007 1:01 am Post subject: |
| cini mi se da nisu iste za allegroa i metroa.... |
Posted: Tue Oct 30, 2007 1:12 am Post subject: |
Pa tu ti sve pise...
Pioneer that led nowhere...
The Austin Allegro was the first car to feature Hydragas suspension - it wasn't a happy beginning.
SINCE the introduction of the Mini in 1959, BLs predecessor, the British Motor Corporation (BMC), had been right at the edge of cutting technology its smallest car popularized front wheel drive and miraculous interior packaging, changing the world in the process.
A mere three years later, BMC gave us even more of the same, with the Austin and Morris 1100 essentially an enlarged Mini with crisp Pininfarina-penned styling and one further innovation: Hydrolastic suspension.
Conceived in the late-Fifties by Dr Alex Moulton, the ingenious Hydrolastic system was the result of his inspired idea to replace conventional suspension units with fluid-filled displacers containing a rubber spring; and then interconnect them with fluid-filled pipes to make it all sit level.
Originally, the Mini was to receive Hydrolastic at its launch in 1959, but Moulton and co-developers, Dunlop, couldnt produce small enough displacers in time for the launch. However, that setback was undone with the launch of the huge-selling 1100 in 1962 and with it, we soon became a nation familiar with the Moulton bounce: that phenomenon of BMCs gently rising and falling on undulating roads.
Endearing then, comical now
BMC refined Hydrolastic during the Sixties, fitting the system to the 1800, 3-litre, Mini and Maxi, before moving on an improved version of the system.
Just as Hydrolastic will always be associated with Sixties BMCs everyone actually wanted, its replacement will be forever associated with that Seventies BL hell child, the Austin Allegro. Yet, the system worked extremely well after a period of fine-tuning. In principle, it was the same as Hydrolastic Hydragas cars had displacers, this time partially filled with nitrogen, separated from the fluid by a rubber membrane, to provide the suspension.
Or in simple terms, Hydrolastic cars were suspended on soft lumps of rubber, Hydragas cars made do with balloons
In effect, the 1970s BLs that used Hydragas rode on a cushion of gas how cool was that?
From 'lastic to 'gas...
Inside a Hydrogas displacer. (Pic: Carbibles.com)
Like the earlier cars, Hydragas cars were interconnected. The reasoning behind this was devilishly simple: when a wheel hits a bump, the suspension compresses, pushing fluid down the interconnecting pipe to the unit at the rear. In other words front wheel goes up, rear wheel goes down and you remain level when you hit a bump.
In early Allegros, Hydragas didnt work too well, though. Damping wasnt strong enough, the ride ended up being too choppy on rough roads, and too floaty everywhere else. The boffins at Longbridge soon worked on ironing out the creases, but customers unconvinced by the earliest cars proved impossible to win back although its suspension was the least of the Allegros problems.
Things improved dramatically with the Princess, which did ride and handle very well, but by the time it was launched in 1975, BL was staring down the barrel of bankruptcy and plans to do anything meaningful with the great Wedge were scuppered by crisis management of disappearing company funds.
Designer of the Rover SD1 and Range Rover, Spen King, was drafted in to create an efficient range of future BLs and in his opinion, Hydragas was unnecessarily complex and costly to produce. That meant the Allegro/Maxi replacement would lose Hydragas, and gain a carbon copy of the VW Golfs MacPherson strut/beam axle set-up.
What was this brave new world? The Maestro
Happily, it wasnt entirely over for Hydragas: BL still needed a supermini, and didnt have the funds to create a brand new car. So, bits of Mini and Allegro were thrown together, the pot was stirred, and four years after being first thought of, the Metro appeared.
King didnt have the resources to engineer Metro to use conventional springs, and kept the Allegros system although to reduce costs and perceived complexity, interconnection was dropped. This denied the Metro of its one major advantage over all its rivals a level ride. It worked well enough, but no better than any of its more conventional rivals and as the Eighties wore on, the Metros knobby ride became the object of derision for many
Except Alex Moulton, who realised the Metro was incredibly compromised when shorn of its extra pipe work. He worked on his own Metro, putting interconnects back in and fiddling with the damping in the Hydragas displacers. And from his workshop in Bradford on Avon, emerged a fine example of automotive alchemy
Rebirth of the system
In 1987, he lent his homemade Metro to CAR magazine, who realised instantly the significance of this innocuous looking brown W-registered Metro. It rode, handled and cornered like a grown up car. News of this miracle soon spread to the Rover development team in Gaydon, who swiftly borrowed the car, and discovered that Hydragas was a long way from being dead and buried.
Rover was on yet another cost cutting drive at the time, and the replacement for the Metro a larger and more conventionally engineered car was in the process of being canned. Moultons car came along just at the right time, because it meant the new cars K-Series engine could be stuffed into the original bodyshell and combined with the sorted version of Hydragas to create a new car thus saving Rover shed loads of cash.
In 1990, the Rover Metro was born and true to its origins, it was a 1980 car, with a 1990 engine and homemade suspension. And yet, it wasnt a disaster it was actually rather good on the road.
Similar thinking brought us the MGF in 1995. Rover needed an MG sports car to compete with the Mazda MX-5, the bosses agreed on a mid-engined design, and so the resourceful engineers at Gaydon took a crateful of Metro engines and front subframes, swapped ends, bolted them together, wrapped them up in smart clothes and created one of the Nineties most successful roadsters.
From this brief resurgence, Hydragas faded from view. The Metro died in 1997, its demise accelerated by poor NCAP crash test results leaving the MGF the only car left using this innovative suspension system. Five years later, the game was up for the MGF, too
no longer a financially viable system MG Rover killed Hydragas, by replacing the Fs displacers with conventional springs. _________________ Might have 16 valves but still a mini! |
Kramer Mini Owner
Mini: Mk3 1969, Special Mk4 1979, Cooper Sport Mk7 2000 Posts: 679 Location: Zagreb
Posted: Tue Oct 30, 2007 12:31 pm Post subject: |
Brute!!!
Ne razbacuj se tako pameæu!!!  _________________ Oni su mali, ali su veliki, mislim nisu vise mali ali su dovoljno veliki da ne budu mali  |
Posted: Tue Oct 30, 2007 7:03 pm Post subject: |
Ne vrijedi ti ovaj ispravak jer ja ionako ne pratim Allegre i Metroe.
Odgovor sam ponudio jer je ovo forum o MINIJIMA i svega to se MINIJA tièe.
Posted: Wed Oct 31, 2007 2:08 am Post subject: |
| to je to MINIJA? |
Posted: Wed Oct 31, 2007 8:52 am Post subject: |
vidis da covek uvezbava promene glagola po licima
minija
miniti
minion
minimi
minivi
minioni
Austin Allegro
Posted: Wed Oct 31, 2007 3:47 pm Post subject: |
| Austin Allegro je se prvo punio hidrogasom odnosno azotom koji je kao gas neutralan tako da nije korozivan za instalacije,a i za samu gumu od bombe!Punile su se bombe do pritiska od 17 bari!Kasnije je doslo vreme hidrolastika koji se u mnogome ne razlikije od azota sto se amortizacije tice,jedina predost je sto se nece odmah spustiti auto kod manjeg pucanja bombe!A u sustini hidrolastik je smesa koju moze bilo ko da na pravi,cak se sastav menja kod razlicitih proizvodjaca drasticno,bilo kako bilo to je sve na bazi alkohola!!! |
FrankJScott
Mini: Best Mastiff Breeds Posts: 63 Location: Best Mastiff Breeds
Posted: Tue Dec 20, 2022 12:18 pm Post subject: Updated Duck Hunting Decoy Details |
In reply to the man inquiring about diy coot decoys, higdon canvasback decoys, mason duck decoys for sale, ducks unlimited decorative decoys, mojo outdoors rippler decoy, resting duck decoys, I highly suggest this useful hunting duck decoy details or urea duck decoys, lightweight duck decoys, duck decoy pond, game winner wood duck decoys, 12 mallard decoys, painting diver duck decoys, alongside all this great hunting duck decoy info as well as custom foam decoys, mallard flocking, remote for mojo decoys, ghg decoys, cal kingsmill decoys, decorative duck carvings, not to mention this great hunting duck decoy link which is also great. also have a look at this recommended hunting duck decoy blog not to mention diy motion duck decoys, decoying wood ducks, motion duck decoys for sale, flambeau classic mallard decoys, brunet decoys, best duck decoys to buy, not to mention this best hunting duck decoy info as well as black friday duck decoy deals, mojo elite series mini mallard drake, john gewerth decoy, mojo teal replacement wings, the best duck decoys, cheap waterfowl decoys, alongside all useful hunting duck decoy link which is also worth a look. i also recommend this awesome hunting duck decoy forum not to mention herters 72 duck decoys, collectable old decoys, cork decoys, higdon battleship decoys for sale, best swimming duck decoy, spinning wing duck decoys, not to mention this recommended hunting duck decoy link not to mention motion decoy companies, ghg long tail decoys, edge expedite duck decoys, old decoys for sale, gadwall decoys 12 pack, black scoter snow goose decoys, alongside all best hunting duck decoy info as well as ringneck decoys for sale, merganser hunting decoys, brant decoys for sale, greenhead gear canvasback decoys, used wood duck decoys, duck decoy quiver magnet, which is also great. finally, have a look at this best hunting duck decoy site with woodie decoys, wind duck decoys, flapping wing decoy, motorized swimming duck decoys, motion duck spreader, water splashing duck decoys, for good measure. _________________ Google it! |
