Posted: Thu Feb 21, 2008 12:46 pm Post subject: Kako smanjiti potrošnju vašeg minija (na engleskom) |
Fuel economy in your MINI is affected by several factors, all of which are under your control. Here are some tips for improving your MINI's gas mileage:
DRIVING TIPS:
Drive smoothly - go easy on the gas pedal when accelerating from a stop and brake gently when coming to a stop. Look ahead to see if you really need more speed.
Observe the speed limit - the faster you drive, the more gas your MINI burns. Driving the speed limit is a good way to conserve fuel.
Use your Cruise Control - driving a constant speed uses less gas than varying your speed.
Keep Windows closed - Open windows create aerodynamic drag at freeway speeds which uses more gas. Open windows when driving at less than highway speeds.
Take less congested route - stop & go driving is very inefficient. Take a less congested route even if it's a slightly longer route.
Avoid excessive idling - turn engine off if you sit still for more than a minute.
Use up the whole tank - don't fill the tank until it's below 1/4 tank. If you like to keep your tank above the 1/2 mark, your MINI is hauling more weight in your tank!
MINI MAINTENANCE
Keep your tires properly inflated - check your MINI manual for proper tire pressures and check them at least once a month. Underinflated tires requires more energy to roll.
Use the recommended grade/viscocity of Motor Oil - yes, using the wrong viscosity can affect your gas mileage! MINI approved oils are in SAE classes 5W-40 and 5W-30.
MINI diet - if you car is loaded with unnecessary 'stuff', unload it! It takes more gas to move more weight. (You can also improve gas mileage by switching to light weight alloy wheels with standard tires. The stock MINI wheels and the runflat tires are quite heavy.)
Keep your MINI properly tuned.
Air Filters - Dirty air filters will reduce engine efficiency leading to reduce fuel economy.
Ignition Wires - Damaged ignition wires reduces the spark energy which leads to reduced fuel economy.
Ignition Coil - Damaged ignition coil reduces the spark energy which leads to reduced fuel economy.
Spark Plugs - Worn spark plugs or plugs with the wrong gap will produce less than optimum spark which leads to reduced fuel economy.
Tire Inflation - Use a high quality tire gauge to accurately check your tires for proper inflation.
Above all, drive sensibly and safely. Plan your driving so you don't make unnecessary trips. Carpool when possible.
Happy Motoring! _________________
pava'oe Mini Owner
Mini: 1000 '77 Posts: 362 Location: Zagreb
Posted: Fri Feb 22, 2008 12:01 am Post subject: |
...kinf ti si CAR  |
vajzgaj Član MCZ
Mini: Zlatko iz '78, somiè ko kuæa Posts: 155 Location: maksimir
Posted: Sun Feb 24, 2008 7:41 pm Post subject: |
NI KORISTI!!!
Trla bablan da joj prodje dan.
 _________________ 2kul4skul |
Posted: Sun Feb 24, 2008 9:26 pm Post subject: |
Bablan ti jednu æuku odgojnu zveknula sunce ti kalaisano  _________________ If You wish to be out front,
Posted: Sun Feb 24, 2008 11:19 pm Post subject: |
Ljepo se vidi tko ima zamjerku na ovaj tekst. A dobro znamo i zato ...  _________________
KUZMA
Mini: nemam ali se nadam da cu s 18 imat Posts: 32 Location: ZGD
Posted: Sun Mar 23, 2008 11:22 am Post subject: |
pa kolko troi mini?? ne troi valjda vie od 10 l??????
 _________________ big mini fan |
Posted: Sun Mar 23, 2008 3:11 pm Post subject: |
Nisi shvatio poantu ...
Ako eli da ti mini JO manje troi onda se pridravaj ovih natuknica. _________________
KUZMA
Posted: Sun Mar 23, 2008 6:15 pm Post subject: |
ma skuio sam ja to nego ovi englezi piu ko da mini troi 15l. ja neznam kolko troi ali nema anse da ide preko 10 l....... ta nije tako?? pa kolka je prosjeèna potronja minija??
drKo Mini Owner
Mini: Cooper 1.3 Spi Posts: 431 Location: Zagreb-Dubrava
Posted: Sun Mar 23, 2008 7:48 pm Post subject: |
ovisi o tipu motora, potelanosti, koju frgu ima i ne najmanje vano koliko ti je teka noga na gasu! A mini te jednostavno tjera da ga stisne. Da ne kenjam dalje, moj SPI 1.3 na otvorenom oko 6.5l po gradu do 10l.  |
KUZMA
Posted: Sun Mar 23, 2008 7:57 pm Post subject: |
pa s tim da je jako lagan nije ni potronja mala!!! ali za taj auto to se da preivjet!!!! _________________ big mini fan |
