Posted: Sun Apr 20, 2008 9:29 pm Post subject: |
Mini Jem
Navodno se proizvodio od '69 do '76
Na zadnjoj slici se vidi razlika izmeðu marcosa i njega. Meni osobno puno ljepi od marcosa  |
Miki Mini Owner
Mini: Innocenti 1001 '72 Posts: 89 Location: Zagreb - Tre?njevka
Posted: Thu May 29, 2008 11:23 am Post subject: |
ABC Tricar
Proizvodio se od 1969 do 1973 bilo je proizvedeno 24 komada, napravljen od fiberglasa _________________ Modern cars - they all look like electric shavers |
Miki Mini Owner
Posted: Thu May 29, 2008 11:30 am Post subject: |
Clubman SRV4
One of five Safety Research Vehicles produced under a joint project between British Leyland and the Transport and Road Research Laboratory. The car has a strengthened passenger cell to withstand a high speed impact, impact resistant low mounted bumpers, a padded interior and a sloping bonnet to minimise injury to pedestrians. The Clubman has a longer wheelbase to allow the engine to be moved forward for better energy absorbtion in the event of a front end collision. The high door sills give greater protection against side impacts. The petrol tank is located under the rear seats.
Miki Mini Owner
Posted: Thu May 29, 2008 11:39 am Post subject: |
Posted: Thu May 29, 2008 1:48 pm Post subject: |
Jbate ! Zakon ! Mini Hovercraft.
Jedan za po Mrenici, 'a Ignore ? _________________
Posted: Thu May 29, 2008 3:11 pm Post subject: |
ajme, tricikel i hover! to jo nisam vidjeo  _________________ www.miniforum.si |
redBeast Admin
Mini: Buco Posts: 452
Posted: Thu May 29, 2008 11:14 pm Post subject: |
koji ludi hover. to je to. s horvacanske drito na jarun, pa malo po savi. zimi kad zapadne snjeg iz dvorista drito po polju do vrha Sljemena.
masta radi svasta!!! |
Posted: Sun Jul 13, 2008 6:25 pm Post subject: |
specijalista
Posted: Tue May 26, 2009 3:38 pm Post subject: |
hahahha ima spaèekov motor... _________________ 2cv - 007 |
žile
Mini: austin mk2 1000 Posts: 11 Location: Split
Posted: Sat Feb 06, 2010 5:19 pm Post subject: |
space shutlle
 _________________ teoretièar zna sve, ne napravi ništa
praktièar nezna ništa, a napravi sve |
Posted: Tue Feb 09, 2010 5:00 pm Post subject: |
Kad sam ga vidio u Zadru ostao sam bez zraka , inace Fiæo rekao da je izgorio  _________________ If You wish to be out front,
Bullythedog Mini Owner
Mini: AUSTIN MINI SALOON 1000 Posts: 15 Location: Zadar
Posted: Mon Apr 05, 2010 4:18 pm Post subject: |
| Se7en wrote: | Kad sam ga vidio u Zadru ostao sam bez zraka , inace Fiæo rekao da je izgorio  |
je ali ga je lik opet obnovio. a covik nema jednu ruku, pa mozete zamisliti koliko volje triba za to. |
Posted: Tue Apr 06, 2010 8:08 am Post subject: |
opet portugalac na izgled sve normalno..
kad vidi zadnju sajbu...??
 _________________ You're only supposed to blow the bloody doors off! |
Posted: Tue Apr 06, 2010 8:09 am Post subject: |
a tek ovo cudo...
gr5.mini prototip... _________________ You're only supposed to blow the bloody doors off! |
rusimir Mini Owner
Mini: Estate Posts: 290 Location: Zadar <-> Zagreb
Posted: Tue Apr 06, 2010 3:44 pm Post subject: |
Sta radi alkohol!! _________________
