How to Time Gravemaker Shots in Close-Quarter Fights in Call
FusionFalcon
PostPosted: Thu Nov 06, 2025 7:04 am    Post subject: How to Time Gravemaker Shots in Close-Quarter Fights in Call Reply with quote
In Call of Duty: Black Ops 7, mastering the use of weapons like the Gravemaker in close-quarter combat can make all the difference between victory and defeat. The Gravemaker, with its explosive rounds, is a powerful tool that can clear tight spaces quickly, but it requires precise timing to maximize its effectiveness. Here’s how to get the most out of this weapon in those intense, up-close encounters.
Understand the Gravemaker's Mechanics
Before we dive into timing your shots, it’s essential to understand how the Gravemaker works. Unlike standard firearms, the Gravemaker has an explosive radius that can damage multiple enemies within a small area. Its projectile speed is slower than most other weapons, meaning you'll need to lead your shots and account for the delay between firing and impact.
In close-quarter battles, where space is limited and enemies often rush in, the Gravemaker can clear rooms quickly, but timing your shots right is critical to avoid wasting ammo or missing your target. The goal is to fire just before your enemy enters the blast radius, ensuring maximum damage when they’re in the perfect spot.
Timing Your Shots
When you're about to engage in close-quarter combat, you need to predict the movement of your opponent. Here are a few tips to help you time your Gravemaker shots effectively:
Wait for the Enemy to Enter the Blast Zone
The key to hitting your target is patience. Don’t rush your shot. Let the enemy enter the effective range of your explosive rounds. Once you know they’re in range, fire just before they’re in direct line with the shot. This will ensure the blast radius catches them at the perfect moment.
Lead Your Shots
The Gravemaker’s explosive rounds don’t travel instantly. You’ll need to lead your shots slightly if your enemy is moving fast. This is especially important in fast-paced close-quarter situations where you’re up against aggressive players who are always on the move. If you’re playing against bots or in a mode like Black Ops 7 bot lobbies, practice leading your shots by aiming slightly ahead of their movement.
Don’t Rely on the Splash Damage Alone
While the Gravemaker is great for clearing spaces, don’t assume that the splash damage will always take care of everything. The blast radius is not as big as some might think. If your target is too far from the explosion center, you may miss the kill. Focus on hitting your target directly or aiming at spots where you expect them to be. U4N often has tips and guides about how to maximize explosive weapons, and the Gravemaker is no exception.
Utilize Cover and Angles
One of the best ways to use the Gravemaker effectively is by utilizing cover. Since close-quarter combat often takes place in areas with lots of corners and tight spaces, using cover allows you to control when and where you take your shots. Don’t rush into the open—wait for your opponent to reveal themselves from behind a corner or through a doorway, and then time your shot. The Gravemaker's explosive rounds are especially powerful in rooms and hallways, where you can catch multiple enemies in a single shot.
Stay Calm and Focused
It’s easy to get flustered when facing a rush of enemies in tight spaces. Remember, timing is everything, so take a deep breath and focus. When using the Gravemaker in close-quarters, don't panic and unload your entire clip. Instead, wait for the right moment to fire, and make sure you’re aiming at the right spot.
If you’re playing in Black Ops 7 bot lobbies or just getting a feel for the weapon, take your time and experiment. You’ll notice that as you get more comfortable with the Gravemaker, you'll start predicting enemy movement and improving your shot timing.
Additional Tips for Close-Quarter Fights
Keep Your Distance
While the Gravemaker is great for close fights, it’s also good to know when to retreat. If you’re overwhelmed, don’t hesitate to back off a bit and reset your position. Giving yourself some room can allow you to take out enemies one by one, rather than getting overwhelmed by a group.
Use the Environment to Your Advantage
In tight spaces, you can often use the environment to control the flow of the fight. For example, if you know enemies will try to rush you through a narrow hallway, position yourself at the end with your Gravemaker ready. When they enter the choke point, you’ll have the perfect shot lined up.
Stay Mobile
Even though you’re working with a powerful weapon, don’t stand still for too long. Moving around and changing positions will make it harder for enemies to predict your location, which is especially helpful in close-quarters. Use the explosive power of the Gravemaker to keep enemies at bay, but always be ready to relocate if needed.
Mastering the Gravemaker in Call of Duty: Black Ops 7 is all about timing and positioning. By being patient and waiting for your opponents to enter the blast radius, you can ensure that each shot counts. Remember to lead your shots, use cover, and keep an eye on your surroundings. With these strategies, you’ll be a pro at handling the Gravemaker in those nail-biting close-quarter fights.
And if you're interested in enhancing your skills, consider trying different game modes. Whether you're practicing in Black Ops 7 bot lobbies or looking for more advanced challenges, always aim for improvement and enjoy the process.
