How to Shiny Hunt Gibble in Pokémon Legends: ZA: A Step-by-S
PostPosted: Mon Nov 10, 2025 3:00 am    Post subject: How to Shiny Hunt Gibble in Pokémon Legends: ZA: A Step-by-S Reply with quote
Shiny hunting is a core part of the Pokémon Legends: ZA experience. One of the most exciting and elusive Pokémon to hunt for is Gibble. The challenge can be tricky, but with the right steps and strategy, you can significantly improve your chances of finding this rare shiny version of the beloved Dragon-type. In this guide, I’ll walk you through how to successfully shiny hunt Gibble using an exploit method that’s both efficient and effective.
Step 1: Setting Up the Wild Zone
The first thing you need to do is head over to Wild Zone 8, where Gibble spawns. This area has various Pokémon spawn points, but our focus is on Gibble, which appears only 10% of the time in these locations.
To increase your chances, you’ll want to create multiple spawn points. The key to this process is clearing out the surrounding Pokémon like Numels, Machops, and Drilbur. By defeating these Pokémon, you reset the spawn rates, essentially creating more opportunities for Gibble to appear. The more spawn points you have, the better your chances. Aim for about six or seven spawn points, preferably in the center of the area.
Step 2: Getting Alpha Drilbur to Spawn
Once you’ve set up your holes, it’s time to get an Alpha Drilbur to spawn. You need an Alpha Drilbur because only the Alpha can learn the move Dig, which is crucial for breaking containment and resetting the spawn pool. Regular Drilbur can’t use Dig, so don’t waste time on them.
You’ll likely encounter a lot of shiny Drilbur during this process, which is not ideal since you’re hunting Gibble. But don’t let this discourage you; keep resetting until an Alpha Drilbur spawns. Once it uses Dig, you can proceed with breaking containment, making it easier for Gibble to spawn.
Step 3: Breaking Containment and Preparing for Gibble
After getting the Alpha Drilbur to use Dig, you’ll need to walk it out of the spawn area. This step is crucial because it ensures that the spawn pool is reset. Be aware of other wild Pokémon like Sandals and Crocooroks that may get in the way, so clear them out as needed.
Once you’ve walked out the Alpha Drilbur, save your game and reload it to confirm the spawn chain has been broken. Then, move at least 60-70 meters away from the spawn point and save again. Reload your game and return to Wild Zone 8 to check if you’ve set up the perfect conditions for Gibble.
Step 4: Creating Gibble Spawns
After setting up the spawn conditions correctly, it’s time to get Gibble to appear. Use the Fly option to reset the spawns in the area. This should guarantee a Gibble spawn as long as everything has been set up properly.
Keep in mind that the Gibble spawn locations are random within the Wild Zone, so you’ll need to reset the area a few times to find a Gibble in the right spot. However, once you’ve managed to get two Gibble spawns, you’ll know that you’ve cracked the method and can start hunting for shiny Gibbles.
Step 5: Shiny Gible Hunting
Now that you have two guaranteed Gibble spawns, it’s time to focus on finding the shiny variant. This will require a bit of patience. The method to do this is simple: fly reset.
Every time you fly back into the Wild Zone, the game will spawn new Pokémon within a 50-meter radius. By repeating the fly reset, you’ll continuously check each spawn until you hear the iconic shiny sound, signaling that a shiny Gibble has appeared.
If you get lucky, you might even encounter multiple shiny Gibbles in a single session. But remember, if you see a shiny Drilbur, avoid catching it. Catching a Drilbur can prevent a Gibble from spawning in that slot, which can set back your shiny hunting progress.
Tips for Success
Patience is key: Shiny hunting can take time, so be prepared to reset and fly in and out of the zone repeatedly.
Use a macro controller: If you want to automate the process, using a controller with a macro function can help. You can leave it running overnight, and with a bit of luck, you’ll return to a shiny Gibble waiting for you.
Avoid catching Drilbur: If you encounter a shiny Drilbur, let it go. Drilbur can fill up valuable slots for Gibble spawns.
Step 6: What to Do After Catching a Shiny Gible
Once you catch a shiny Gibble, you’ll need to reset your process to get another one. From my experience, it’s possible to get up to two Gibbles at a time using this method, but you’ll need to go through the steps again to capture more.
If you're really dedicated to shiny hunting, you might want to consider buying shiny Pokémon through trusted sources, especially if you're looking for a shiny with specific traits or abilities. Just remember to always check reviews and make sure you're getting your Pokémon from reputable vendors.
Additionally, if you want to buy Legends ZA Pokémon, places like U4GM offer a variety of in-game services that can help you secure the Pokémon you’re hunting for.
Shiny hunting for Gibble in Pokémon Legends: ZA is an exciting challenge that requires patience and persistence. By following the steps outlined above, you can significantly improve your chances of getting that shiny Gibble. It’s all about setting up the right conditions, using the fly reset method, and avoiding distractions like shiny Drilbur. With a bit of luck, you’ll soon have your own shiny Gibble to add to your collection.
