DaffyDeer
Posted: Thu Jan 15, 2026 6:32 am Post subject: Arc Raiders Tips: Monitoring Filtration and Purification Sys |
If you’re diving into Arc Raiders and want to understand how the “The Clean Dream” quest works, this guide breaks it down clearly. Most players want to know exactly what to do, where to go, and what to expect, so we’ll go step by step without overhyping anything.
Who Gives “The Clean Dream” Quest?
The quest is given by Apollo, a trader you meet after completing the previous quest, With A Trace. Apollo is located at the Spaceport, near the Blue Gate. In general, players who have finished the earlier quest will see “The Clean Dream” become available automatically.
Apollo’s instructions are straightforward: he wants you to monitor purification systems in the tunnels and gather data that could help him with his explosive designs. Most players don’t need to worry about combat in this stage; it’s mostly exploration and observation.
Where Do You Go for the Quest?
The quest is split between two main locations:
Spaceport Underground Tunnels
You’ll need to search 4 containers scattered through the tunnels.
Keep an eye out for any Filtration Systems. These are usually in less obvious corners, so take your time and move carefully.
Most players tend to explore in a zigzag pattern to ensure they don’t miss any containers or systems.
Blue Gate Maintenance Bunker
After checking the tunnels, head to the Maintenance Bunker at Blue Gate.
Here, you’ll monitor the Purification System and collect additional data.
You also need to find and photograph blueprints in the bunker, which is a critical step for quest completion.
What Do You Need to Complete This Quest?
In practice, players usually have to manage a few items to get through this quest efficiently:
Deadline ×1
Showstopper ×3
Heavy Fuze Grenade ×3
Most players stock up on these before starting, as they can be useful if the tunnels or bunker are guarded by enemies or environmental hazards.
How the Quest Works in Practice
Once you accept the quest, Apollo gives a bit of flavor text about his dreams of a talking water distiller and better explosives. In general, this is just lore, but it helps players understand why the tasks matter.
In the tunnels:
You’ll spend most of your time checking containers and monitoring the filtration system.
Players usually scan the area slowly, noting any interactive objects.
There’s no strict time limit, but staying cautious reduces mistakes, especially when navigating tighter sections.
In the bunker:
Monitoring the purification system is mostly interactive. You’ll examine machinery, check readings, and eventually photograph blueprints.
Most players find this stage easier than the tunnels because it’s more contained and less open to random spawns.
After completing both sections, returning to Apollo triggers the completion dialogue. He’ll remark on the blueprints you found and thank you for your help.
Tips and Common Player Behavior
Take your time: Many players rush through tunnels and miss containers or filtration points. Slow exploration is generally more effective.
Interact with everything: The quest requires monitoring systems, so scanning or activating anything that looks like machinery usually counts.
Use your inventory wisely: Carry items like grenades in case of enemy encounters, though for most players, combat is minimal.
Blueprints: Photographing them is mandatory. Most players overlook this step initially, which delays quest completion.
Some players also look for ways to optimize rewards or reduce grind. While the game doesn’t officially support trading, players sometimes try to buy Arc Raiders items cheap to speed up preparation for quests like this. It’s not necessary, but having extra resources makes the process smoother.
Common Questions About “The Clean Dream”
Q: Do I need to fight enemies in this quest?
In general, combat is minimal. The focus is on exploration and interacting with machinery. You might encounter minor hazards, but most players report that careful movement avoids most problems.
Q: How long does the quest usually take?
Depending on experience, it usually takes 15–30 minutes to complete both tunnels and the bunker. Players unfamiliar with the layout might take longer.
Q: Can I miss anything?
Yes. The 4 containers in the tunnels and the blueprints in the bunker are easy to overlook. Make sure to check every corner and scan all interactive objects.
Q: Are there rewards for completion?
Rewards are primarily story progression and some in-game resources. There’s no special item from this quest alone that players consistently use for combat advantages.
“The Clean Dream” is a relatively straightforward Arc Raiders quest, but it requires careful exploration and attention to detail. Most players benefit from:
Slow, methodical exploration
Carrying necessary items
Ensuring all containers and blueprints are accounted for
Understanding these practical aspects makes the quest smoother and reduces frustration. Once finished, you’ll have completed Apollo’s storyline segment and gathered the necessary data for future quests.
Editor's Choice: buy ARC Raiders Coins at U4N |
