FusionFalcon
Posted: Mon Jan 19, 2026 3:09 am Post subject: ARC Raiders Anvil Splitter Blueprint: A Comprehensive Guide |
The Anvil Splitter is a powerful weapon mod in ARC Raiders, designed for the Anvil weapon. If you're looking to improve your Anvil's performance and add an interesting twist to its functionality, the Anvil Splitter is a mod you should consider. In this guide, we'll break down everything you need to know about the Anvil Splitter Blueprint, its uses, and how to get your hands on it.
What is the Anvil Splitter Mod?
The Anvil Splitter is a legendary weapon mod that changes the behavior of the Anvil weapon. Instead of firing a single, high-damage projectile, the Anvil Splitter causes the Anvil to shoot four weaker projectiles at once. This is a significant shift in how the weapon operates and can provide both advantages and disadvantages depending on your playstyle.
Key Features of the Anvil Splitter Mod:
Increased Projectiles: +3 projectiles per shot.
Reduced Damage: The projectile damage is reduced by 70%.
Weight: The mod has a weight of 0.5, which is relatively light, allowing you to maintain mobility.
Sell Price: If you're looking to sell it, the Anvil Splitter has a sell price of 7,000 coins.
How Does the Anvil Splitter Affect Gameplay?
The Anvil Splitter provides a unique playstyle that can be both rewarding and challenging.
Damage Trade-off: While you get more projectiles, the reduced damage per projectile means that you’ll need to be more accurate with your shots. It's perfect for situations where you need to hit multiple targets or spread damage across a wider area.
Crowd Control: The additional projectiles make the Anvil Splitter a great choice for dealing with groups of enemies. It’s particularly useful in situations where you need to spread damage over a large area or hit multiple enemies at once.
Playstyle Shift: Players who are used to the standard, high-damage single projectiles of the Anvil may find the Anvil Splitter a bit tricky at first. However, once you get used to the new mechanics, it can be a very versatile mod, especially in multiplayer situations.
How to Obtain the Anvil Splitter Blueprint?
To get the Anvil Splitter Blueprint, you’ll need to focus on scavenging. This involves exploring the game's world and collecting the necessary resources to craft the blueprint. Keep in mind that scavenging for rare blueprints can be time-consuming, so make sure you’re prepared for the grind.
Recycling and Salvaging the Anvil Splitter
If you ever want to break down your Anvil Splitter, you can recycle or salvage it for valuable resources:
Recycling: You’ll get 1 Mod Component and 1 Processor.
Salvaging: You’ll receive 2 Mechanical Components.
These resources can be reused to craft or upgrade other mods and components, so recycling and salvaging is a good option if you no longer need the Anvil Splitter or if you want to repurpose its materials.
Should You Sell the Anvil Splitter?
If you're looking to make some quick coins in the game, you might consider selling the Anvil Splitter. With a sell price of 7,000 coins, it can provide a decent amount of currency. However, before selling, consider whether you’ll need the mod in the future. If you're an avid Anvil user or plan to experiment with different builds, it might be worth keeping.
The Anvil Splitter is a unique and strategic weapon mod that can completely change how the Anvil performs in combat. While it reduces individual projectile damage, it compensates by increasing the number of projectiles fired. This makes it an excellent choice for players who want to tackle groups of enemies or spread damage over a wide area. Whether you’re scavenging for it or deciding whether to sell it, understanding the trade-offs and benefits of the Anvil Splitter will help you make the most of this mod.
If you're planning to sell ARC Raiders items or simply want to use the Anvil Splitter for your next mission, this guide should give you a solid understanding of how it works in practice. Happy raiding!
Meta Watch: How to Obtain the Arc Raiders Anvil Blueprint |
