Posted: Sat Feb 28, 2026 7:11 am Post subject: Avoiding Predictable Pitch Patterns in MLB The Show 26 |
As an experienced player of MLB The Show 26, one of the most important skills to develop is the ability to avoid predictable pitch patterns. Whether you’re batting or pitching, the game’s mechanics reward variety, and sticking to the same pitch or location too often will make you vulnerable. In this article, we'll cover the common pitfalls players fall into when it comes to pitching and how to avoid being too predictable in your approach.
Why is Avoiding Predictable Pitch Patterns Important?
In MLB The Show 26, pitchers have a variety of tools to keep batters off balance. From pitch selection to pitch location, each choice you make can affect the outcome of an at-bat. If you're constantly throwing the same type of pitch or throwing to the same location, batters will catch on, and it becomes much easier for them to time your pitches and make solid contact.
This is a key aspect of why players struggle in higher difficulties or against more experienced opponents. Batters can often "read" a pitcher’s tendencies after just a few pitches, especially when the pitch types or locations are repeated.
So, what can you do to avoid falling into predictable patterns and losing control of the game?
How Do Predictable Pitch Patterns Develop?
Predictable pitch patterns often develop in one of two ways:
1. Pitch Type Overuse
Throwing the same type of pitch over and over is a common mistake. For example, relying too heavily on fastballs or sliders might seem safe, but once the batter notices the trend, they’ll sit on that pitch and time it more effectively.
2. Location Overuse
Pitching to the same spot repeatedly can also make you predictable. If you're always throwing high and outside, or always attacking the low corner of the strike zone, a batter will know where to expect the next pitch.
As a result, changing both your pitch type and location frequently is crucial to staying effective.
How Can I Avoid Being Predictable as a Pitcher?
There are several strategies you can use to keep your pitches varied and make yourself less predictable. These tips focus on both pitch selection and placement.
1. Use the Entire Strike Zone
A big mistake many pitchers make is focusing on one part of the strike zone, either staying high, low, inside, or outside. To keep batters on their toes, try to mix up your pitch locations across all parts of the zone. For example:
Start with a fastball inside, then throw a curveball low and away.
Throw a changeup high and then follow up with a slider on the outside corner.
By keeping the batter guessing about where the next pitch is going, you make it harder for them to time it.
2. Mix Up Your Pitch Types
Even within the same at-bat, changing pitch types can disrupt a batter’s timing. A fastball followed by a changeup can completely throw off a hitter’s swing. Likewise, mixing in breaking balls like sliders, curves, and even a knuckleball (if you have one) will force the batter to adjust.
An effective pitcher doesn’t just rely on one or two pitches. If you're always going to the same pitch (like a fastball on a 3-2 count), batters will eventually catch on. Keep them guessing.
3. Use the Offspeed Pitches Early
Throwing offspeed pitches like changeups or curveballs early in an at-bat can set up your harder pitches for later. Batters are more likely to swing through or miss a fastball after they've been thrown off by an offspeed pitch.
For example, start with a changeup in the first pitch, then follow up with a fastball on the next. You’ll find that batters have to work harder to adjust.
4. Change Speeds
Throwing pitches at different speeds is a great way to keep batters guessing. If you throw a fastball and then follow it up with a slower curveball or changeup, batters will have to adjust to the new tempo. The difference in speed can make it harder for them to pick up the ball in time, which leads to weak contact or swings and misses.
A good approach is to mix between fastballs, breaking balls, and offspeed pitches, varying the speed of each to keep the batter from getting too comfortable.
5. Be Unpredictable in Key Counts
In important situations, like with two strikes or when the batter is behind in the count, pitchers tend to throw more predictable pitches. Many pitchers will throw a fastball to try to get a strikeout, or throw a curveball expecting the batter to swing at a bad pitch.
Instead, consider throwing something unexpected. A well-placed changeup or slider when you expect the batter to be looking for a fastball can catch them off guard.
6. Watch for Patterns in the Batter’s Approach
Even though you don’t want to be predictable, it’s also important to pay attention to the batter’s tendencies. If a batter tends to swing at high pitches, you can throw more of those to get them out. But don’t get too predictable yourself — if they’ve been hitting high pitches well, you’ll want to adjust accordingly. Recognizing the batter's patterns allows you to stay one step ahead of them.
How Can I Stay Unpredictable as a Batter?
Just like pitchers need to mix up their approach, batters also need to avoid falling into predictable habits. If you’re always swinging at the first pitch or swinging at pitches in the same location, pitchers will catch on. To stay unpredictable as a batter:
Mix up your swing timing by occasionally holding off on a pitch to get ahead in the count.
Be patient and let pitches come to you, instead of trying to force an early swing.
Change up your stance or timing to throw off the pitcher’s rhythm.
When you keep the pitcher on edge, you’ll increase your chances of success.
How Does Pitching Strategy Affect Your Team’s Performance?
Pitching strategy doesn’t just impact your individual performance — it can shift the entire game. When you effectively mix pitches and locations, it forces the opposing team to adjust and rethink their strategy, often leading to more strikeouts and weaker contact. On the other hand, sticking to the same predictable patterns can result in giving up more hits and making it easier for the batter to get on base.
The more you diversify your pitch choices and locations, the better chance you have to dominate the game. This doesn't just improve your performance as a pitcher but elevates the defense behind you too. If batters are swinging at bad pitches and not getting solid contact, your fielders will have an easier time getting outs.
Where’s the Best Place to Buy MLB The Show 26 Stubs?
If you’re looking to enhance your MLB The Show 26 experience by purchasing stubs, it's always a good idea to look for the best deals. While you have several options, make sure to choose a reputable platform that offers fair pricing and good customer support. Many players have found that the best place to buy MLB The Show 26 stubs is from trusted sources, whether directly from the game's marketplace or other authorized sellers.
Avoiding predictable pitch patterns in MLB The Show 26 requires a mix of strategy, observation, and adaptation. By varying your pitch types, locations, and timing, you’ll make it harder for the batter to settle into a rhythm. Whether you're a beginner or an advanced player, keeping your pitches unpredictable will give you the upper hand. Just remember: variety is key in staying one step ahead, and by mixing it up, you'll increase your chances of success. |
