Step-by-Step Guide to Fix MLB The Show 26 Online Errors on P
FusionFalcon
PostPosted: Tue Apr 28, 2026 6:36 am    Post subject: Step-by-Step Guide to Fix MLB The Show 26 Online Errors on P Reply with quote
1. Verify Server and Console Status
Before tweaking your PS5 or network, make sure the issue isn’t on the developer’s end.
Check Game Servers: Go to the MLB The Show X Twitter
page or use Down Detector
to see if servers are offline. MLB The Show maintenance often occurs around 4 AM PT / 7 AM ET.
Check PlayStation Network: Ensure PSN services are fully operational via PSN Status
Update Your PS5: Go to Settings > System > System Software Update and Settings to make sure your console is running the latest software.
2. Optimize PS5 Network Settings
Sometimes your console’s connection to your router causes errors. These steps can stabilize it.
Change DNS Settings:
Go to Settings > Network > Settings > Set Up Internet Connection.
Highlight your active connection, press Options, and choose Advanced Settings.
Set DNS Settings to Manual.
Use Google DNS: Primary 8.8.8.8, Secondary 8.8.4.4. Or Cloudflare DNS: 1.1.1.1 / 1.0.0.1.
Fix Wi-Fi Frequency: Change Wi-Fi Frequency Bands from Automatic to 5 GHz for speed or 2.4 GHz for stability.
Restore Licenses: Go to Settings > Users and Accounts > Other > Restore Licenses. This re-syncs your access to the game.
3. Adjust In-Game Features
Some PS5 display and matchmaking features can cause crashes or errors.
Disable 120Hz and VRR: Go to Settings > Screen and Video > Video Output, then turn Enable 120Hz Output and Variable Refresh Rate (VRR) off.
Toggle Crossplay: If you can’t find opponents, go to your in-game profile (top left) and turn Crossplay off. This can reduce matchmaking errors.
4. Advanced Network Fixes
If the game still disconnects, your router might be blocking key connections.
Power Cycle Devices: Turn off your PS5 and router, unplug both for 60 seconds, then restart.
Use a Wired Connection: An Ethernet cable is far more reliable than Wi-Fi, especially for online matches.
Port Forwarding: Open your router settings and forward these ports to your PS5 to get NAT Type 2 (recommended for online stability):
TCP: 80, 443, 3478, 3479, 3480
UDP: 3478, 3479
Following these steps usually resolves most MLB The Show 26 connection issues on PS5. Start with server checks, then move to console and network tweaks, and finally try advanced fixes if needed. With a stable setup, you can focus on hitting homers instead of dealing with network errors.
