Efficient Path to MLB The Show 26 Cityscapes Program Rewards
PostPosted: Tue May 05, 2026 4:05 am    Post subject: Efficient Path to MLB The Show 26 Cityscapes Program Rewards Reply with quote
If you want to earn all the Cityscapes Program rewards in MLB The Show 26 without wasting time, the key is to combine missions, Moments, and Conquest efficiently. As an experienced gamer, here’s how to hit every milestone quickly while stacking multiple rewards in a single game session.
1. Instant Progress: Moments & Conquest
Start by grabbing the low-hanging rewards. You don’t need a specialized lineup for these:
Moments: Complete the five Cityscapes Moments. Each gives 5 Program Points, totaling 25 points right off the bat. These also drop initial Cityscapes player cards.
Conquest Map: Clear the Cityscapes Conquest map to earn two Cityscapes Deluxe Packs. You’ll also find hidden rewards like standard Show Packs and Stubs along the way.
Mini Seasons: Playing the Cityscapes-themed Mini Season nets extra player cards and often another Deluxe Pack. Focus on easy victories using your best lineup to maximize points and drops.
Pro Tip: Complete Moments first. They feed into missions and give cards you’ll need to stack PXP efficiently later.
2. Efficient Mission Stacking
To minimize total games played, plan a lineup that tackles multiple missions at once. Here’s the most effective approach:
Priority Mission Objective Program Points Efficiency Tip
High 6,000 PXP with any players 10 Counts toward almost all other rewards. Use your strongest hitters to speed this up.
High 2,000 & 4,000 PXP with Cityscapes cards 20 Use cards from Moments and Conquest immediately to cover these missions.
Medium 1,000 PXP (Cubs/White Sox) 10 Rotate players from these teams to hit multiple missions at once.
Medium 1,000 PXP (Brewers/Braves/Orioles) 10 These teams overlap with other missions for faster points.
Stat-Based 18 Strikeouts / 20 Runs 20 Focus on these during Conquest or Mini Season games for max efficiency.
Pro Tip: Use players that double-count for PXP and stats simultaneously. For example, a Cityscapes pitcher in a Mini Season game earns both PXP and strikeout stats.
3. Complete the Cityscapes Collection
For top-tier rewards, collecting the cards is essential. You can earn up to 60 points through general missions and another 80 points through PXP-specific missions.
Key Milestones:
12 Cards: 92 OVR Clay Buchholz (BOS)
24 Cards: 93 OVR Jimmy Rollins (PHI)
30 Cards: 93 OVR Mickey Mantle (NYY)
Pro Tip: Trade in duplicates via the Exchange section to fill gaps faster and avoid grinding the same packs repeatedly.
4. Top Program Rewards
Progressing through the 100-point program unlocks multiple rewards:
Stubs: Over 10,000 Stubs total.
Packs: "The Show" packs, Headliners, and a Ballin’ is a Habit pack at 50 points.
Bonus Rewards: Additional bonuses appear at 20, 40, 60, 80, 95, and 100 points, giving extra packs, XP, and sometimes rare Cityscapes cards.
Final Tips for Maximum Efficiency
Stack missions whenever possible: Build lineups that check multiple boxes in one game.
Prioritize Moments & Conquest early: Unlock cards you’ll need for PXP missions.
Use Exchanges smartly: Turn duplicates into missing cards to hit collection milestones faster.
Mini Seasons are repeatable: Use them to rack up stats and points with minimal downtime.
Following this path, you’ll unlock all Cityscapes rewards faster while spending fewer games grinding.
