Posted: Thu Jun 18, 2026 8:29 am Post subject: How to Get the Ladder Crate in Grow A Garden 2 |
If you've been working on your plot in Grow A Garden 2 lately, you've probably realized that building horizontally only gets you so far. Whether you are trying to reach those high-up fruit branches or designing a beautifully layered, multi-level layout, verticality is key. That is exactly where ladders come into play. To start climbing higher, you'll want to get your hands on a Ladder Crate.
Unlike standard decorations or basic crops, grabbing a Ladder Crate takes a bit of specific planning and a decent chunk of savings. Here is a practical walkthrough on exactly where to go, what to look for, and how to start expanding your garden upward.
Step-by-Step Guide
Getting the crate is straightforward once you know where the right shop is hidden and have enough pocket change saved up from your harvests.
Visit the Marketplace: First, spawn in or make your way over to the central marketplace hub. This is the main town square area where all the primary shops and player services are clustered together.
Locate the Props Shop: Scan the row of stores for a distinct pink storefront. This is the Props Shop, the go-to place for structural additions and functional garden items.
Buy the Crate: Walk inside and interact with the shop vendor NPC. Open up the shop catalog, scroll down until you spot the Ladder Crate, and buy it. It will cost you exactly 30,000 Sheckles, so make sure you've farmed enough crops beforehand to cover the price tag.
Open the Crate: Once purchased, head back out to your personal garden plot. Open your inventory, select the newly acquired crate, and place it down on the ground. Give it just a brief moment, and it will pop open automatically to reveal your reward.
Quick Tip: 30,000 Sheckles can feel like a steep investment early on. Prioritize high-yield crops for a few rotation cycles before making the trip to town so you don't completely drain your funds!
Available Drops & Rarities
Every single Ladder Crate you open grants you one random, permanent ladder type. You don't have to worry about these breaking or disappearing after use. Depending on your luck, you will pull one of four distinct variants:
Ladder (Common)
Dark Oak Ladder (Common)
Gold Ladder (Rare / Legendary variant)
Rainbow Ladder (Ultra Rare variant)
How to Use Your New Ladders
Once you've unboxed a ladder, putting it to work is incredibly simple. Ladders are perfect for scaling steep vertical structures or effortlessly reaching tall plants and hanging fruits that are otherwise out of arm's reach.
To place one down, open your main Build Menu and tap on the Build option. From there, navigate to your prop inventory where your unlocked ladder types are stored. Select the one you want to use, position it against any vertical surface or structure in your garden, and confirm the placement. You can move or rearrange them whenever you decide to re-engineer your layout! |
