POZDRAV
customr25
Mini: mini 74 1000
PostPosted: Mon Feb 02, 2009 2:20 am    Post subject: POZDRAV Reply with quote
POZDRAV SVIMA *BYE*
DA SE PREDSTAVIM, ROBERT
IMAM MINI PA SAM ODLUCIO DA SE PRIDRUZIM NA FORUM
PostPosted: Mon Feb 02, 2009 9:43 am    Post subject: Reply with quote
tako treba, dobrodošao. ajde stavi fotke svoga miniju u podforum "garaža"
minimalac
Mini: 1000 iz `70.
PostPosted: Mon Feb 02, 2009 10:02 am    Post subject: Reply with quote
Bok *BYE*
PostPosted: Mon Feb 02, 2009 10:33 am    Post subject: Reply with quote
Pozdrav i dobrodosao! *BYE*
Se7en
Mini: njema
PostPosted: Mon Feb 02, 2009 12:50 pm    Post subject: Reply with quote
Vozdra Robi
If You wish to be out front,
Lao Tzu
customr25
Mini: mini 74 1000
PostPosted: Mon Feb 02, 2009 5:24 pm    Post subject: Reply with quote
Dan,evo,slike ce za koji dan, treba da sredim garage pa da mogu poslikat u kakvom je stanju moj mali, nije jos u voznom stanju al nadam se da ce uskoro bit
minimalac
Mini: 1000 iz `70.
PostPosted: Tue Feb 03, 2009 8:20 am    Post subject: Reply with quote
daj mi se javi na mob 091/10 59 456. Èesto sam poslovno u ÈK, pa æe mi biti drago vidjeti Shocked Shocked što imaš u garaži.
ignore
Član MCZ
Mini: minor 850 '68, clubman 1000 '72, estate 1000 '80
PostPosted: Tue Feb 03, 2009 8:45 am    Post subject: Reply with quote
Drinks or Beer
?piC gEtriBA i sTrAigHt cUt kLipi !
Silvo
Mini: Cooper x2, Clubman estate `81
PostPosted: Tue Feb 03, 2009 10:11 am    Post subject: Reply with quote
pozdrav *HI*
Ni bed milo!
customr25
Mini: mini 74 1000
PostPosted: Tue Feb 03, 2009 5:35 pm    Post subject: Reply with quote
Pozdrav,svima!!!
Imam jedno pitanje,
-jel mi moze netko rec vrijednost Austin Allegra 1300,neznam tocno godiste
74,75 bi moglo bit
-Javit cu se minimalac bit ce mi drago
Instructor
Mini: Austin Mini 1975.
PostPosted: Tue Feb 03, 2009 9:51 pm    Post subject: Reply with quote
Pozdrav ACUTE
bitna je volja...
Mat Black
PostPosted: Thu Feb 05, 2009 7:50 am    Post subject: Reply with quote
dobrodošao *HAT*
MINI mi je hrana
MINI mi je sisa materina
pava'oe
Mini: 1000 '77
PostPosted: Fri Feb 06, 2009 9:59 am    Post subject: Reply with quote
bok book *HAT*
PostPosted: Fri Feb 06, 2009 12:58 pm    Post subject: Reply with quote
bok, bok.
nezahvalno je govoriti o cijeni Allegra ako se nezna u kakvom stanju. vrijedi toliko koliko ti je drago imati njegov motor za svog minija. inaèe je postao jako rijedak, pa bi ga osobno saèuvao i pomogao da preživi..... .to jest nebi ga koristio za donaciju i transplataciju organa.
customr25
Mini: mini 74 1000
PostPosted: Fri Feb 06, 2009 5:23 pm    Post subject: Reply with quote
Pozdrav Minici
allegro je u super stanju, 12 godina je bio u garazi spremljen
e sad covjek nezna sta on hoce za njega jer on ga ne zeli restaurirat, pa sam ja odlucio uzet i sredit
neznam kakvu ponudu dat zqa njega
