Mjere za stezanje kilokljuèem (Torque Settings)
PostPosted: Wed Feb 08, 2012 12:59 pm    Post subject: Mjere za stezanje kilokljuèem (Torque Settings) Reply with quote
Text zapis:
Fastener Torque (lbft) Torque (kgm)
Drive shaft coupling U bolts (rubber cross inner joints) 8 to 12 1.11 to 1.66
Drive shaft nut (front hub, drum brakes). Continue tightening until next split pin slot aligns. Do not slacken off until the next slot aligns! 60 8.3
Tie rod to front subframe 20 to 24 2.8 to 3.3
Tie rod to lower front suspension wishbone 17 to 20 2.8 to 3.3
Front suspension upper support arm pivot shaft nut 45 to 60 6.2 to 8.3
Front suspension lower wishbone pivot shaft nut 30 to 35 4.1 to 4.8
Wheel nuts 40 to 45 5.5 to 6.2
Steering column/rack pinion clamp bolt 8 to 10 1.11 to 1.38
Steering arm to swivel hub 30 to 35 4.1 to 4.8
Steering track-rod end to steering arm 20 to 24 2.8 to 3.3
Steering-wheel nut 32 to 37 4.5 to 5.1
Swivel hub ball joint socket 70 to 80 9.6 to 11.1
Swivel hub ball joint to suspension arms 35 to 40 4.8 to 5.5
Track rod end to steering rack locknut 35 to 40 4.8 to 5.5
Steering rack U-bolts to floor 10 to 12 1.4 to 1.7
Steering-column clip bracket to cloumn clip and parcel shelf 13 to 18 1.8 to 2.5
Rear suspension rear hub nut. Continue tightening until next split pin slot aligns. Do not slacken off until the next slot aligns! 60 8.3
Rear radius arm pivot shaft nut 45 to 60 6.2 to 8.3
Backplate to rear radius arm bolts 18 to 22 2.5 to 3.0
Suspension and Steering, Mini Cooper 997/998cc
Caliper retaining bolts 35 to 40 4.8 to 5.5
Steering Lever ball joint 25 to 30 3.4 to 4.1
Suspension and Steering, Mini Cooper S Mk1-3
Drive Shaft Nut. Continue tightening until next split pin slot aligns. Do not slacken off until the next slot aligns! 150 20.7
Electrical Components
Fastener Torque (lbin) Torque (kgm)
Alternator (11AC) Brush box fixing screws 10 0.115
Alternator (11AC) Diode heat sink fixings 25 0.288
Alternator (11AC) through-bolts 45 to 50 0.518 to 0.576
Alternator (16ACR) Shaft nut 25 to 30 3.5 to 4.2
Distributor Clamp Bolt (fixed nut type) 50 0.576
Distributor Clab Bolt (fixed bolt type) 30 0.345
Engine (848cc, 998cc)
Camshaft Nut 60 to 70 8.3 to 9.7
Con Rod Big-end Bolts 35 to 38 4.8 to 5.3
Crankshaft Pulley Nut 70 to 80 9.7 to 11.1
Cylinder Head Stud Nuts 40 5.5
Cylinder Side Cover 3 to 4 0.42 to 0.55
Clutch Spring Housing to Pressure Plate set screws 16 2.2
Driving Strap to Flywheel set screw 16 2.2
Flywheel Centre Bolt 110 to 115 15.2 to 15.9
Flywheel Housing bolts and stud nuts 18 2.5
Gudgeon Pin Clamp Screws 22 to 25 3.0 to 3.5
Heater Control to Cylinder Head 6 to 8 0.83 to 1.11
Main Bearing set screws 60 to 65 8.3 to 9.0
Manifold to Cylinder Head 12 to 16 1.7 to 2.2
Oil Filter Bown Centre Bolt 12 to 16 1.7 to 2.2
Oil Pump 6 to 9 0.83 to 1.25
Oil Pipe banjo 35 to 40 4.8 to 5.5
Oil Pressure Release Valve - dome nut 40 to 45 5.5 to 6.2
Rocker Cover 3 to 4 0.41 to 0.55
Rocker Shaft Bracket Nuts 22 to 25 3.0 to 3.5
Spark Plugs 18 2.5
Timing Cover and Front Plate 1/4in UNF bolts 4 to 6 0.55 to 0.83
Timing Cover and Front Plate 5/16in UNF bolts 10 to 14 1.4 to 1.9
Water Pump 14 to 18 1.9 to 2.5
Water Outlet Elbow 6 to 9 0.83 to 1.25
Thermal Transmitter 16 2.2
Engine (970cc, 1071cc, 1275cc)
Use this data in conjuction with the data for Engine (850, 998cc)
Cylinder Head nuts (11 stud head) 42 5.8
Cylinder Head bolt (11 stud head) 25 3.5
Con Rod Big-end nuts (assemble dry only) 40 5.5
Main Bearing set screws (early type) 67 9.3
Main Bearing nuts (later type) 57 7.9
Gearbox
Third Motion Shaft bearing retainer screws 13 1.8
First Motion Shaft nut 150 20.7
Third Motion Shaft nut 150 20.7
Transmission Case to Crankcase 6 0.8
Transmission drain plug 25 3.5
Transmission case studs - 3/8in dia. UNC 8 1.1
Transmission case studs - 5/16in dia. UNC 6 0.8
Transmission case stud nuts 3/8in UNF 25 3.4
Transmission case stud nuts 5/16in UNF 18 2.5
Bottom Cover set screws 1/4in dia. UNC (change-speed tower) 6 0.8
Final Drive
Driven Gear to Differential Cage 60 8.3
Driving Flange to Differential nut (tighten to next split pin hole) 70 9.6
Differential Housing End Cover bolts 18 2.5
PostPosted: Sat Feb 11, 2012 10:20 am    Post subject: Reply with quote
*HI*
super tabela. sve na jednom mjestu!!!
FrankJScott
Mini: Best Mastiff Breeds
PostPosted: Tue Dec 06, 2022 11:24 am    Post subject: Updated Yak Merino Wool Details Reply with quote
In response to the guy inquiring about merino thermal underwear, merino wool womens thermals, mens red long underwear, polo ralph lauren waffle, I highly suggest this new thermals for men link as well as flannel thermals, ski thermal base layer womens, 3x thermal underwear, black long underwear top, merino wool long johns, men's tall thermal long johns, under armor ski base layer, carhartt thermal tops, look at this great merino wool base layer link on top of terramar merino woolskins base layer, camo long underwear, patagonia lightweight long underwear, smartwool thermal base layer, merino thermals womens, smartwool 250 base layer, black long sleeve thermal shirt, long sleeve wool base layer, try this excellent merino wool base layer advice for wool turtleneck base layer, merino 365 base layer, merino wool long underwear women's, long underpants mens, 100 cotton thermal underwear, mens smartwool merino 250, smartwool merino wool base layer womens, under armour merino wool base layer, not forgeting this great thermals for men tips as well as mens thermal pajama pants, smart wool base layers, merino base layer hoodie, black thermal undershirt, tommy hilfiger thermal, 150 merino wool base layer, best 100 merino wool base layer, most comfortable long johns, as well this excellent thermals for men advice for long sleeve thermal sports top, affliction thermal shirts, best thermal pants mens, white thermal undershirt, polo ralph lauren waffle, smartwool base layer bottoms mens, tesla thermal underwear, 100 cotton long johns, See More @ Top Rated Yak Merino Wool Tips 56_59a0
Google it!
View user's profile Send private message Send e-mail Visit poster's website AIM Address
FrankJScott
PostPosted: Tue Dec 20, 2022 11:07 am    Post subject: Great Essay Writing Service Blog Reply with quote
In reply to the guy talking about ecommerce copywriting, research paper writing, ai paper writer, order essay cheap, paperell, buy essay online safe, I highly recommend this high rated essay writing service forum or research writing services, article and blog writing, white paper writing services, grabmyessay, content writing, content writing upwork, on top of this great essay writing service details as well as do my assignment cheap, cheap paper writing service, personal statement writing service, assignment writer, business proposal writing services, writing and editing, as well as this top rated essay writing service tips which is also great. also have a look at this top essay writing service advice not to mention freelance copywriting services, professional writers near me, samedayessay, phd thesis writing services, cheap essay writer, best paper writing services, alongside all this top rated essay writing service link and don't forget dissertation writing services, write my research paper cheap, saas writing, ghostwriting services, affordable business plan writing services, help me write my paper, as well as great essay writing service info which is also worth a look. i also suggest this awesome essay writing service tips as well as scholarship essay writing service, paper writers cheap, buy dissertation online, thesis write up, buy essay online reddit, web copywriting, not to mention this recommended essay writing service details on top of website copywriting services, custom dissertation, essay websites for students, seo copywriting services, personal statement writing service, content writing services pricing, and don't forget top essay writing service blog not to mention editing in writing, professional essay writers, assignment writers near me, dissertation services, write my paper, buy essay online cheap, which is also great. finally, have a look at this high rated essay writing service url with best coursework writing service, cheap custom essay, speech writing services, editing writing, seo content writing, cheap essay writing service, for good measure.
Google it!
comme44
PostPosted: Fri May 08, 2026 4:11 am    Post subject: Reply with quote
Useful torque specs! Regarding tie rod ends, ensuring consistent torque is crucial. A simple miscalculation, even with a slope 2 error in tightening sequence can lead to premature wear or failure. Has anyone experimented with anti-seize compounds on these threads? Any specific recommendations for brand or type?
delhicallgirl
PostPosted: Thu Jul 30, 2026 8:15 am    Post subject: Sensual Delhi Call Girls: A Place Where Reality and Desire C Reply with quote
The Best Place To Find Gorgeous Local Call Girls in Delhi If you are looking for a trustworthy and excellent way to meet attractive call girls in Delhi, check out Delhi Call Girls, the best brand in the city for sincere, excellent company. Delhi Call Girls is your doorway to an unforgettable experience with elegant, attractive women. Delhi Call Girls is renowned for its reliable service and verified profiles.
Delhi Call Girls skillfully and professionally offers discreet companionship, passion, or charm. Enter a world of captivating encounters and enhance your moments with Delhi's best don't settle for anything less. 2100+ Updated List Delhi Call Girl WhatsApp Number: If you are looking for a genuine and direct relationship with a call girl in Delhi, you have come to the right place. Our website has the most up-to-date list of the personal mobile numbers and WhatsApp numbers of over 2100 call girls. Every listing is careful to ensure that you have access to the most recent contacts.
Delhi's Housewife Call Girls Provide A Wide Range Of Sexy Services https://delhi69.gfnyt.com/
Our Delhi call girls are the perfect example of a wealthy friendship. Each one is chosen with care due to her knowledge, charisma, and ability to create a truly unforgettable experience. These ladies are masters of the art of connection, fulfillment, and communication; they are much more than just attractive faces. Regularly interacting with a diverse clientele enables them to quickly understand and adapt to a variety of backgrounds, preferences, and needs. Whether your demands are physical, emotional, or social, our housewives in Delhi are committed to meeting them discreetly, gracefully, and with genuine passion.
Delhi69 seductive housewife call girl in Delhi, experience a world where your most extravagant dreams come true. These stunning women are dedicated to provide you with an unforgettable experience that will stimulate your senses, in addition to being experts in seduction. From start to finish, they deliver excellent exotic services with confidence, composure, and zeal. Their unmatched skills and sincere commitment ensure your satisfaction at every turn. You have the chance to accept your best ideas and give in to your need for pure pleasure tonight.
Read More: Delhi Call Girl !! Delhi Escort !! Escort Delhi !! Delhi Call Girls !! Call Girl Delhi !! Call Girls Delhi !! Escort in Delhi !! Call Girl in Delhi !! Call Girls in Delhi !! VIP Call Girls Delhi !! Delhi Call Girls Number !! Escort Service in Delhi !! Delhi Escorts Service !! Delhi Call Girls Near Me !! Call Girl Services in Delhi !! Dating Call Girls Delhi !! Delhi Call Girl Whatsapp Number !! Best Call Girls Service in Delhi !! Independent Call Girl in Delhi !! Top Class Call Girls in Delhi !! Delhi Call Girl Phone Number !! Delhi Call Girls Service Near Me
View user's profile Send private message Visit poster's website
delhicallgirl
PostPosted: Fri Jul 31, 2026 7:36 am    Post subject: Premium Escort Agency in Andheri With 450+ Sexy Call Girls Reply with quote
Welcome to Andheri Call Girls, the most trusted name in adult entertainment across Andheri city. If you are looking for genuine, high-quality companionship that goes beyond the ordinary, you have landed at the right place. Our Andheri Call Girls agency has been serving professionals, tourists, and pleasure seekers who demand nothing less than the best.
We bring you a carefully curated selection of female Call Girls who combine natural beauty, warm personality, and exceptional skills to deliver an experience you will not forget. Whether you need a classy companion for a business dinner, a hot partner for an intimate evening, or someone to share deep connection and quality time with, Our Call Girls in Andheri covers every need. We operate round the clock because we understand that desires do not follow a schedule.
Why Our Andheri Call Girl Service Stands Apart From the Rest
The Call Girl industry in Maharastra has grown significantly, but not every provider delivers what they promise. What makes us different is our commitment to authenticity, privacy, and complete satisfaction. Every independent Andheri Call Girl on our roster goes through a thorough verification process.
We check profiles, verify identities, and ensure that every Call Girls meets our high standards before she joins the team. Our clients come back because they know they are dealing with a genuine person every single time. No fake photos, no bait-and-switch tactics, no hidden charges. When you book Call Girls in Andheri through us, the girl you see in the profile is the girl who shows up at your door.
************** Different Locations **************
Call Girls in Kolkata !! Call Girls in Agra !! Call Girls in Ahmedabad !! Call Girls in Ajmer !! Call Girls in Allahabad !! Call Girls in Ambala !! Call Girls in Amritsar !! Call Girls in Andheri !! Call Girls in Bangalore !! Call Girls in Bhopal !! Call Girls in Bhubaneswar !! Call Girls in Chennai !! Call Girls in Daman !! Call Girls in Dehradun !! Call Girls in Dwarka !! Call Girls in Faridabad !! Call Girls in Ghaziabad !! Call Girls in Goa !! Call Girls in Gurgaon !! Call Girls in Guwahati !! Call Girls in Haridwar !! Call Girls in Hinjewadi !! Call Girls in Hyderabad !! Call Girls in Indore !! Call Girls in Jaipur !! Call Girls in Jalandhar !! Call Girls in Jammu !! Call Girls in Jamshedpur !! Call Girls in Jodhpur !! Call Girls in Karnal !! Call Girls in Kochi !! Call Girls in Koregaon Park !! Call Girls in Lonavala !! Call Girls in Lucknow !! Call Girls in Ludhiana !! Call Girls in Mahipalpur !! Call Girls in Manali !! Call Girls in Mira Road !! Call Girls in Mumbai !! Call Girls in Navi Mumbai !! Call Girls in Noida !! Call Girls in Patna !! Call Girls in Pune !! Call Girls in Pushkar !! Call Girls in Raipur !! Call Girls in Ranchi !! Call Girls in Rishikesh !! Call Girls in Shimla !! Call Girls in Surat !! Call Girls in Thane !! Call Girls in Udaipur !! Call Girls in Vadodara !! Call Girls in Varanasi !! Call Girls in Viman Nagar !! Call Girls in Visakhapatnam !! Call Girls in Wakad !! Call Girls in Nagpur !! Call Girls in Coimbatore !! Call Girls in Secunderabad !! Call Girls in Nashik
