Posted: Sat Sep 13, 2008 9:11 am Post subject: |
Posted: Sat Sep 13, 2008 2:04 pm Post subject: |
Pa ovi ima 2 rezervara, a britvele i klizne prozore su imali samo mk1 i 2,dva rezervara na cooperima su dola posli 67 ako se ne varam |
Posted: Mon Sep 15, 2008 3:27 pm Post subject: |
Jeaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaah
jebenoooooooooooooo
nek je dosao u prave ruke, joj da mi je bilo vidit ti facu kad si ga ugledao _________________ If You wish to be out front,
Posted: Mon Sep 15, 2008 5:28 pm Post subject: |
Darjan wrote: | Pa ovi ima 2 rezervara, a britvele i klizne prozore su imali samo mk1 i 2,dva rezervara na cooperima su dola posli 67 ako se ne varam |
Samo Cooper Sovi su imali dva rezervoara! _________________ Might have 16 valves but still a mini! |
Knot
Mini: RAJNGLICA 71 i sinovi... Posts: 36
Posted: Mon Sep 15, 2008 9:10 pm Post subject: |
Tako puno lipih stvari,
a vas brinu ''rezervari''...?!
Jedanaest erafa... tri u jedan mjuza...
a vas brine rupa, to æiri na te zguza...?!
Praznik za oèi, melem na ranu,
nadam se, Kinfa, bi'æe za hranu...
Èovjeku kom' problem svaki bude mala ala,
teribilni je infant pripo', nek' je, maala...! _________________ Pa, kak ti fali ulja...?! |
Posted: Mon Sep 15, 2008 10:40 pm Post subject: |
Ti si neki aljivdija,ha?
Svaka èast na rimama, tekstopisac! |
Posted: Tue Sep 16, 2008 6:26 am Post subject: |
Koliko su ti Cooper S-ovi troili kad im je malo jedan rezervoar _________________ MINI mi je hrana
MINI mi je sisa materina |
buba_ze Član MCZ
Mini: Mayfair, 1983 Posts: 184 Location: Zenica
Posted: Tue Sep 16, 2008 7:57 am Post subject: |
Zavrne u stomaku kada se vidi nesto ovako. Svaka cast, ovo je jedan od malo dokaza da se kockice slazu kako treba. Mozemo samo pozeliti jos ovakvih slucajeva za ostatak miniljubaca.
Sretno, valja se nagledati, nastavljaj sa postom, neka se narod uci nauci po svim fazama, jos ti blog kakav fali.
Vozdra od bubaze tima _________________ BubaZE team vozilice:
Fijakeri Victoria 1903 i 1906, slavonska kola 1957, fijaker custom made 2007, VW buba 1971, VW T2 1971, Mini 1983... |
Posted: Thu Sep 18, 2008 1:06 pm Post subject: |
Posted: Thu Sep 18, 2008 10:02 pm Post subject: |
joj Kinfa biti æe mi zadovoljstvo pratiti slaganje Kupresa na ovim stranicama!
i ja se nadam da æe ostati neto za hranu! |
Gajudin
Mini: 1000 Posts: 45
Posted: Sat Oct 18, 2008 2:57 pm Post subject: |
LU DI LO
scaka cast druze ovako nesto vidim prvi put
sta vise reci....ostao sam bez reci _________________ ZIV JE MINI UMRO NIJE |
Johnny Mini Owner
Mini: Austin 850 '76 Posts: 139 Location: Zagreb
Posted: Wed Oct 22, 2008 3:01 pm Post subject: |
Svaka cast bas mi je drago...
Jedva cekam da ga vidim slozenog |
nebkv Mini Owner
Mini: 1000 Posts: 27 Location: Kraljevo
Posted: Wed Dec 24, 2008 12:16 am Post subject: |
Zaista sjajan pronalazk
U casopisu "Mini magazine" broj 125 izasao je tekst bas o Mini Kuperu S mk3.Ako nemas taj broj mogao bih skenirati kao ovu prvu stranu i postaviti ovde i ostale.Moze ti vredeti u radu.
Posted: Thu Dec 25, 2008 3:24 pm Post subject: |
Fakin wrote: | Dao sam upit u British Motor Heritage, na osnovu broja asije, motora i "commission number-a", da mi pronaðu tvornièke specifikacije tj "Technical specification" za njega pa æu onda definitivno znati kakve je boje originalno bio. |
I jesi dobio odgovor kakve je boje bio? |
