Posted: Thu Feb 25, 2010 8:18 am Post subject: |
jebate koje dobre pante
shine on you crazy diamond _________________ You're only supposed to blow the bloody doors off! |
Posted: Wed Mar 03, 2010 10:11 pm Post subject: |
Koliko bojaaaa...koliko prièa...koliko poslaaaa
malo po malo ... _________________ ?piC gEtriBA i sTrAigHt cUt kLipi ! |
Posted: Thu Mar 04, 2010 1:25 am Post subject: |
ha ha,do jaja. ova prva fotka izgleda kao umjetnièka slika! isprintaj si ju i na zid! |
Posted: Thu Mar 04, 2010 8:08 pm Post subject: |
Sve ce to ionako uskoro prekriti korica... _________________ You're only supposed to blow the bloody doors off! |
KREŠŠO
Posts: 252 Location: REMIZA
Posted: Fri Mar 05, 2010 10:02 am Post subject: |
Lilihip wrote: | ha ha,do jaja. ova prva fotka izgleda kao umjetnièka slika! isprintaj si ju i na zid! |
HA HA Edo Murtiæ "riganje po platnu"3000evra prvi put,drugi put i prodano
gosponu sa rokezom _________________ KREŠ/METAL |
Posted: Thu Mar 25, 2010 7:59 pm Post subject: |
Ima li novosti, kako napreduju radovi? |
Posted: Thu Mar 25, 2010 9:54 pm Post subject: |
na pripremi je.... _________________ ?piC gEtriBA i sTrAigHt cUt kLipi ! |
Posted: Mon Mar 29, 2010 11:03 pm Post subject: |
Posted: Tue Mar 30, 2010 12:30 am Post subject: |
aaaw! kakav Mk1 dan ha! |
Posted: Tue Mar 30, 2010 6:47 am Post subject: |
aha brrm brrm jos da ih sve pokrenemo brmmm brmmm _________________ You're only supposed to blow the bloody doors off! |
Posted: Tue Mar 30, 2010 10:12 am Post subject: |
nemogu više pratiti sve projekte na forumu. pa ovo se odvija veè serijski...
dali uopšte spavate, jedete?
èestitam i skidam kapicu. _________________ www.miniforum.si |
Posted: Tue Mar 30, 2010 6:05 pm Post subject: |
Sudeci po tome kako su im pune garaze, sumnjam da nesto pametnije rade osim minica |
Posted: Tue Mar 30, 2010 9:54 pm Post subject: |
sutra i preksutra nabijam hemeroide pred kompom treba zaraditi nofce pa petak malo sarafljenja da odrzim formu, BTW imam j..... musklfiber
sad mi je jasno zakaj je ignore tak vizljast on je ipak u garazi svaki dan, meni to dojde mjesto teretane _________________ You're only supposed to blow the bloody doors off! |
Posted: Thu Jun 17, 2010 7:47 pm Post subject: |
Jeee... ipak se posložilo!!!!!... imam sad i hidro mostove i hidrolastik i oko motorne sitnice (taže nabavive) ...pojase ...krovni tap ...razerna vrata u super stanju....mini je 68. mk2 trenutno donator....limarijski puno bolji neg mk1 kaj je bil...njega rastavljam...pumpam hidro i ostavljam ga na mjesec dva da vidim dali je hidro ok i onda sve pjeskarim i repariram ...a školjku pak isto pjeskarim i èuvam za neke nove prièe...
A imamo sad Ziggy i ja i mjesto di bumo držali školjke nako lakiranja, pjeskarenja i vse ostale hobi speake ,speakice i speaketine ...
Mali Jura veè zaražen... je bez ustruèavanja izvršil prvi zadatak naukovanja
