MMOexp:Two Hitting Tips That Will Instantly Improve Your MLB
Florencehg
PostPosted: Mon Jun 22, 2026 9:16 am    Post subject: MMOexp:Two Hitting Tips That Will Instantly Improve Your MLB Reply with quote
In MLB The Show 26, many players end up swinging at everything or missing pitches they clearly saw coming. Good pitches feel impossible to hit, while bad pitches keep getting chased. The issue is rarely pure reaction speed. It usually comes from not having a structured hitting approach. This guide breaks down two core practical techniques that can turn you from a guessing hitter into a MLB The Show 26 Stubs selective, consistent contact player who gets on base more often and strings together hits.
STEP ONE: NOT READING THE RELEASE POINT IS LIKE SWINGING BLINDFOLDED
A lot of buy MLB The Show 26 Stubs players step into the batter's box and start guessing immediately. That is the biggest mistake.
Every pitcher has a different release point. Some release the ball high, some low, some slightly to the side. If you don't know where the ball is coming from, you are basically swinging blind.
The solution is simple. Watch the first pitch and do not swing. Track the full path from the pitcher's hand to the catcher's mitt and memorize that release point.
You have nine innings to figure it out, but the earlier you lock it in, the faster you start producing hits.
Remember: anything outside the strike zone is a ball. Do not rush. See it clearly first.
STEP TWO: LEARN TO READ PITCH TYPES INSTEAD OF FALLING FOR THEM
Knowing the release point is not enough. You also need to recognize pitch behavior.
A fastball travels straight. A slider slightly "jumps" before breaking sideways. A cutter starts straight then moves late. A sinker drops downward as it approaches the plate.
Each pitch type has subtle visual clues in its release and early movement. The more you observe, the easier it becomes to identify them in real time.
Once you recognize the pitch type early, the decision becomes simple: if it is not your pitch, take it.
STEP THREE: DEFINE YOUR SWEET SPOT AND WAIT FOR IT
Every hitter has a preferred damage zone. Some perform better inside high fastballs, others prefer low outside pitches.
Your job is to identify your own sweet spot, then commit to it.
Before two strikes, you should not swing at pitches outside your zone. Period.
No pitcher is perfect. Eventually, mistakes will come. That is when you attack. Chasing bad pitches only leads to outs.
STEP FOUR: 10-MINUTE PRE-GAME ROUTINE THAT CHANGES EVERYTHING
Do not jump straight into ranked or online games.
Instead, spend 10 to 15 minutes in custom practice:
Choose a pitcher with fastballs and sliders
Study the difference between release and early movement
Practice taking bad pitches
Only swing at pitches in the strike zone
Mix good and bad pitches until your decisions become consistent
After this, your in-game hitting will feel noticeably more controlled.
STEP FIVE: RESET YOUR FOCUS BETWEEN PITCHES
Do not stare continuously at the release point. Your eyes will fatigue quickly, and your timing will suffer.
Between pitches, blink, look away briefly, and reset your focus. When the pitcher begins the motion again, re-engage fully for those 2–3 seconds.
Fresh eyes lead to clearer reads.
SUMMARY
WHO THIS IS FOR:
Players struggling with low batting averages and constant swings and misses
Intermediate players who understand mechanics but lack strategy
Free-to-play players who rely on skill instead of high-rated cards
VALUE YOU GET:
You do not need better cards or expensive setups. By improving pitch reading, release recognition, and swing discipline, you can significantly improve performance and consistency.
QUICK TIPS
Every pitcher has a different release point, watch the first pitch carefully
Fastball is straight, slider jumps, sinker drops-learn the patterns
Define your sweet spot and avoid swinging outside it before two strikes
Spend 10 minutes in practice mode before online games
Reset your eyes between pitches to maintain focus
CORE BENEFITS BY PLAYER TYPE
New Players: Build correct hitting habits from the start and stop random swinging, leading to faster improvement in batting consistency.
Players at a Skill Plateau: Fix overlooked weaknesses such as pitch recognition and release point reading to break through performance ceilings.
Free-to-Play Players: Win through strategy and discipline instead of expensive cards, improving competitiveness without spending money.
Competitive Ranked Players: Develop a structured hitting system to maintain consistency under pressure and improve on-base reliability in ranked matches.
