Maurerre
Posted: Wed Jul 22, 2026 7:40 am Post subject: Solar Smash Guide: How to Unlock All Secret Planets Quickly |
Solar Smash is one of the most addicting 3D sandbox physics simulators available today. While blasting Earth with nuclear missiles and alien superweapons is undeniably fun, the real excitement comes from discovering hidden Secret Planets.
If you want to expand your cosmic collection fast, here is the ultimate short guide to unlocking all secret planets in Solar Smash!
1. Quick Recipes for Secret Planets in Solar Smash
Follow these simple step-by-step tricks to unlock every hidden world:
Flat Earth: Select Earth. Use the custom Laser to slice off the top and bottom poles until the planet resembles a flat disc. Tap Reset.
Donut Earth: Follow the steps for Flat Earth. Once you have a flat disc, blast a large hole straight through the center with your laser. Tap Reset.
Cube Earth: Open the Grid Settings (gear icon with a grid) and max out all sliders to form a cube around Earth. Carefully carve away everything outside the grid lines using lasers, then tap Reset.
Snowman Planet: Freeze 100% of Earth’s surface using the Freeze Ray until it turns completely white. Once the achievement pops up, press Reset.
Pumpkin Planet: Use thermal weapons (like the Solar Beam) to burn Earth until its surface glows bright orange like a Halloween pumpkin, then quickly tap Reset.
The Sun: Select Mars. Aim at the Sun in the background and launch a continuous barrage of missiles or UFOs at it until it explodes into a supernova.
2. Top Weapons & Customization Hacks
To make planetary destruction even easier, make sure to take advantage of these weapon settings:
Custom Lasers: Tap the gear icon next to the Laser weapon to boost its Power and Size to maximum. This lets you cut planets in half in less than two seconds.
Space Monsters: Summon the Space Kraken or Celestial Dragon to strip away planetary shields automatically.
Black Holes: Spawn multiple black holes near the planet’s mantle to pull the core apart with gravitational force.
3. Frequently Asked Questions (FAQ)
How do I reset a planet in Solar Smash?
Simply tap the curved arrow Reset Button on the left panel to instantly restore your planet to full health.
Is Solar Smash free to play?
Yes! Solar Smash is 100% free to play on mobile devices (iOS/Android) and web browsers with zero installation required.
Conclusion
Unlocking secret planets in Solar Smash is easy once you know the exact steps. Try out these quick recipes today, customize your superweapons, and take full control of the galaxy! |
